WAAS monitoring
raindrop18
is there any one monitoring WAAS using open source SNMP monitoring Apps. especially Cacti. i am very interested if some one share the expericance. Thanks.
I'm not using cacti to pull any stats from the WAAAS as it only gives me interface byte counts, which I can get that directly off of the switch interafce if I really wanted to.
Here is a link to where you can see what's available in the supported WAAS MIBS.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v431/configuration/guide/SNMP.html#wp1107077
johng231
Level 3
Level 3
I been asking for that for a long time now and the answer is still no! You only get basic SNMP stats from the MIBS. All the performance stats you see in the CM can only be pulled from it via an API interface.
Thanks for your time. so would you tell me what are those basics things I can monitor via snmp from WAAS including if you know OID list for them.
Thanks, Apperciated!
