Basic transparent caching questions:
mm7482
Level 2
Level 2
I am attempting to perform web caching with one 7325 that has two interfaces connected to two different VLAN's on the same 6500. Although I currently have this working, I ran into lots of problems getting it to work and don't really have a good reason why it wasn't working for most of the day. Therefore, I would like to cover some basics first (since I'm a beginner CDN'er.)
1) Is it possible to dual-home a CE via two different network connections?
2) Do I have to specify any/all interfaces of the 6500 in my CE router list if all of the interfaces are on the same CE? Note: "show ip wccp" on the 6500 does show that the CE has been contacted and redirects are ocurring.
3) the "router id" that wccp uses is actually my router-id specified in my OSPF commands of the 6500. Does this create a problem with the fact that this address is not specified in my router list?
Below are the highlights of the WCCP router and CE config. Thanks for any advice.
ROUTER:
ip wccp web-cache redirect-list 100
access-list 100 deny ip any 128.228.0.0 0.0.255.255
access-list 100 permit tcp any any eq www
interface Vlan144
ip address 199.219.144.3 255.255.255.0
no ip unreachables
ip wccp web-cache redirect out
ip route-cache same-interface
interface Vlan145
description STUDENTBACKBONE
ip address 10.10.2.1 255.255.255.0
CE:
interface GigabitEthernet 1/0
ip address 10.10.2.225 255.255.255.0
exit
interface GigabitEthernet 2/0
ip address 199.219.144.225 255.255.255.0
exit
wccp router-list 1 10.10.2.1 199.219.144.3
wccp web-cache router-list-num 1 l2-redirect
wccp version 2
Gilles Dufour
1/ is ok
2/ the wccp router-list should contain at least 1 ip address of the router.
I never no by heart if this is the router-id or the physical interface ip that we have to use, so I usually configure both.
3/ the router-id has no significance except identifying the different routers if there are more than one.
Whatever ip being used is ok so we usually do not pay too much attention to it.
Regarding the config, I don't see why you have redirect out configured on vlan 145.
Are there any web servers on this vlan ?
And if so, do you really need to intercept the traffic ?
I would remove this command from this interface.
Gilles.
Giles,
Thanks for input. The deal with VLAN 145 opens "Pandora's box". The customer has a PIX which only NAT's private addresses before they go to the internet PIX. This NAT PIX has its inside interface on VLAN 145 (route map statements aren't shown in config) and its outside interface on VLAN 144. VLAN 144 also has the inside interface of the internet PIX. The reason why I redirected on VLAN 144 was that I figured an ICMP redirect would be sent to the NAT PIX telling him the best hop to get to the internet was the INTERNET PIX inside address and; therefore, the WCCP redirect on VLAN 144 would only catch web-cache stuff for public addressed clients. Its pretty ugly and I think plays into some of my problems.
Last night from furstration with lack of consistent operability, I changed the two CE uplinks to ether-channel and addressed it with 199.219.144.225. I kept all the WCCP info the same and internet access/caching worked the very first time.
Thanks again for the input on my config Giles.
Mike.
