Best HTTP load balancing method
theletterz
Community Member
This is probably basic, but how satisfactory is this http load balancing method:
service http-1
ip address 192.168.1.10
protocol tcp
port 80
keepalive type tcp
active
service http-2
ip address 192.168.1.9
protocol tcp
port 80
keepalive type tcp
active
owner http
content web-domains
vip address 10.0.0.1
add service http-1
add service http-2
protocol tcp
port 80
balance leastconn
active
Should I rather use sticky-mask 255.255.255.255 or advanced-balance sticky-srcip?
Gilles Dufour
It really depends what you are doing.
Some people will find this acceptable and for others it will just not work.
Do you need persistency ?
To answer this question check with your webserver admin.
does this website have a shopping basket ?
Finally, changing the sticky-mask is useless if you do not have sticky-srcip. So your question should be ..or .. but .. and ..
Anyway, it all depends what is required for your website to work.
You can try this config and if you run into problem capture a sniffer trace and identify the problem to see if a configuration change is needed.
Gilles.
Gilles Dufour
Gilles.
