box-to-box redundancy
dschleyer
I´m a little bit confused about the config guide ragarding box-to-box redundancy.
customer will use 2 Css 11503 and wants to configure box-to-box redundancy.
There is one advice that it is essary to link the two switches via a FE-Port. but i also fond an advice that a GE-Port can be used.
What is right? It´s depending on sw-version ?
Thank you for your help
regards
Dietrich Schleyer
Gilles Dufour
Dietrich,
initially it was necessary for this link to be FE.
With the most recent versions this link can also be a GE link.
Since this link is only being used for some kind of keepalive between the 2 CSS, I don't see the need to use GigE.
Also, unless your customer is doing firewall loadbalancing, you should really convince him to use vip/interface redundancy and not box-to-box redundancy.
You get faster failover time with vip/interface red., you can turn on statefull failover [not possible with box-to-box] and it is easier to troubleshoot.
Gilles.
Thanks for rating this answer.
