Can CEs on ACNS 5.0 be upgraded using CiscoWorks
drussell
The existing documentation isn't particularly clear about whether you can upgrade a CE that is running ACNS 5.0 to a newer 5.x version (once it comes out) using CiscoWorks. The 4.0 version could be configured as ECDN or not. That command is gone now. I am guessing that the CE is in ECDN mode only now but that is just a guess.
didyap
Level 6
Level 6
That's my guess too since the command seems to be missing from the command reference. I am not sure if the cache and ecdn technologies have been integrated in the 5.0 version. Could someone shed more light on this?
I don't know if you can do it via CiscoWorks anymore but you can upgrade all the CE from the CDM device.
You need to enable CMS (Centralised Management system).
