¿Can I manage ACE through a virtual context other than ADMIN?
rogelioalvez
Hello team:
I am being requested to setup a context for bridged mode balancing. So I am making two vlan interfaces belong to the same bridge group.
In addition, there is a temporary restriction by which customer can not build a separate VLAN for ACE management. So for the time being my customer would like to carry out ACE management by reaching the BVI on the virtual context I will create. ¿ Is this possible? Can I manage the box via a virtual context other than the ADMIN one?
Any hints will be greatly appreciated
Best regards
Rogelio Alvez
Borys Berlog
Hi Rogelio
You will be able to manage  this particular context. Command "changeto" won't be available for this user, so you won't be able to go to another context.
Borys Berlog
Hi Rogelio
rogelioalvez
Thank you very much Borys!
So in short I just can have limited management of that context itself. But full administration will only be available in the Admin context.
Best regards, Rogelii
