Can you use WAEs for conns going over IPSEC?
mmertens
Question: Can you place WAEs and optimize traffic and then place over IPSEC? Has anyone done this and have you experienced sufficient optimization? I'm picturing some in-line module WAEs between enddevices and IPSEC routers and wanted to know if I could expect typical optimization performance.
Thanks! Mike.
Zach Seils
Level 7
Level 7
Mike,
Are planning to deploying the WAE's in the traffic prior before/after IPSec encryption occurs? If so, you should be fine.
Zach
Yes, it would be the non-IPSEC traffic. IPSEC would be on the inside of the WAE WAN interfaces. Thanks!
