cifs accelerator stopping every few mins
Brian Cartledge
CIFS service is disabling itself. Re-enabling it will work okay for a few mins. Running 4.1.5.c on a 512.
Critical Alarms:
     Alarm ID             Module/Submodule     Instance
   1 svcdisabled          nodemgr              cifsao
     Jan 12 09:56:19.508 EET, Processing Error Alarm, #000005, 2000:330001
     nodemgr: The cifsao service has been disabled.
Major Alarms:
   1 tfo_accl_wellness    sysmon               accl=CIFS
     Jan 12 09:56:40.402 EET, Processing Error Alarm, #000006, 1000:445005
     CIFS accelerator keepalive failure.
Any pointers as to what could be causing this?
TIA
devsharma
Have u checked the Rx.internal.log (on edge) or Tx.internal.log (on core) file? Please also check tcp-errlog-proxy file as well. It might give you some indication.From my experience with WAAS platform, 90% of the time it is a software bug.
CSCsx73347 might be what u are experiencing, but it should have been resolved.
Dev
