CIFS File Permissions Problem
plato9888
Has anyone else experienced this?  I have a remote site setup using a WAAS 574 in inline mode (connected to a 2811 router) and whenever I enable the CIFS Accelerator on the device (and the Central Office WAAS) the remote site end users start gaining access to each other’s files?  Not all of them, just files that someone else was accessing recently.  It seems like the CIFS Accelerator has recently accessed files cached and doesn’t check the User rights on Active Directory for some reason.  I have CIFS disabled for now but I would love to re-enable it.  FYI – The File Server being accessed is a MS Windows 2008 R2 will all Service Packs and Updates installed.
ahskhan
Hi William,
Do you know if this is a newly installed server and if Share
configured on this server are ABE (Access-bases Enumeration). If yes then
you would need to configure them as dynamic shares in WAAS. See below link.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v431/configurati
on/guide/filesvr.html#wpxref89338
Ahsan
