CIFS Script
james.robinson
Community Member
Here are the first lines of output from a Cisco script that finds files in the cifs folder:
KQPGXTF#script execute cifsdir-new.sh
Directory: drwxrwxrwx 4 admin root 4096 Dec 30 17:34 /obj1/data/cifs/
ls: drwxrwxrwx: No such file or directory
ls: 4: No such file or directory
ls: admin: No such file or directory
ls: root: No such file or directory
ls: 4096: No such file or directory
ls: Dec: No such file or directory
ls: 30: No such file or directory
ls: 17:34: No such file or directory
/obj1/data/cifs/:
total 16
drwxrwxrwx    4 admin    root         4096 Dec 30 17:34 .
drwxrwxrwx    4 admin    root         4096 Dec 29 16:55 ..
drwxrwxrwx    3 admin    root         4096 Dec 30 17:34 eagnmnsg55a.usps.gov
drwxrwxrwx    3 admin    root         4096 Dec 29 16:55 rlghncsxd28.devsub.dev.v
I am unable to drill down manually using cd or ls commands from the local1 directory.    Are the directories above hidden?
ahskhan
  You can use script in below format.
script execute cifsdir-new.sh eagnmnsg55a.usps.gov
This will show you the content on this folder. you can then drill down like
script execute cifsdir-new.sh eagnmnsg55a.usps.gov/folder1/folder2
Hope this helps
Ahsan
Yes, it helps a lot. Thanks very much.
Jim Robinson
Verizon Business
Government Enterprise NOC (GENOC)
