Virtual Blade Not set to Autostart
Dan Loring
How do I set the virtual blade to autostart.  After MS updates we did a reboot, and the server did not come back up until I went into the Central Manager and selected "Start Virtual Blade".  Is there a setting in there to make sure the blade is set to autostart?
ahskhan
Can you check and see if Auto Start is checked for this Virtual
blade configuration and it is set to boot from disk rather cdrom? See below
link
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v411/configurati
on/guide/virtual.html#wp1051532
Ahsan
ahskhan
link
Ahsan
Yes, it is checked now. Thank you!  I knew it was right under my nose.
