Cisco 11050 Capabilities
ifullerton
I have a CSS11050 running fine with 9 servers in 3 different pools. I use 1 port of the CSS to connect to a switch, and I use the switch to connect the 9 servers. I have plans to connect an addition 2 servers in the same manner. At present the CSS doesn't seem to be labouring.
I looking for a spec on what the CSS11050 can handle in both numbers of connctions from clients, and the number of servers that can be typically be set up. The CSS11050 has 8 physical connections but I don't think this is a limiting factor given the configuration I have described above. The CSS 11050 has a backplane speed of 5 Gig which is the same as the next range of CSS (11150)
so I don't really see what the difference is.
Anyone with ideas on what the CSS11050 capabilities are, would be much appreciated.
