cisco ACE - control load balancing based in known source ip address
Carlos T
Hi.
I want to statically control which know client source IP address (/32) will be redirected or balanced to a specific real server in the server farm.
Is it possible to do it in cisco ace? if yes, please explain how to do it?
Let explain what I want with an example:
I want to force Client A to always be redirected to real server A, while Client B to always be redirected to real server B, If I have a new client, for example client C I want to have the control, to always redirect his connections to real server A.  Real servers A, B and C are members of the same server farm.
sivaksiv
I dont see a point of loadbalancing here if you want to statically map individual ip to real server
one way i can think of is to match based on src ip under class-map and point that to your real server
sample config:
class-map match-any CD-VIP
  3 match virtual-address x.x.x.x eq any
serverfarm SF1
  rserver A
    inservice
serverfarm SF2
  rserver B
    inservice
class-map type http loadbalance match-any SRC-IP-A
  2 match source-address a.a.a.a 255.255.255.255
class-map type http loadbalance match-any SRC-IP-B
   2 match source-address b.b.b.b 255.255.255.255
policy-map type loadbalance first-match Policy1
  class SRC-IP-A
    serverfarm SF1
  class SRC-IP-B
     serverfarm SF2
policy-map multi-match Mpolicy1
  class CD-VIP
    loadbalance vip inservice
    loadbalance policy Policy1
    loadbalance vip icmp-reply
    loadbalance vip advertise
interface vlan yyy
service-pilicy .....
Siva
Hi Siva,
I do have similar requirement where, we have three application URL/Server say for example X, Y and Z and we have end user subnets A, B and C. requirement is if a user with A subnet reaches Loadbalancer it has to route to X URL, respectivity if a user with B subnet reaches load balancer it has to route to Y URL. But end user need to have single VIP, VIP has redirect to respective URLs based on source IP subnet. How we can achive this in Cisco ACE and what are the steps
Hi Fareed,
I haven't done this but you can use the above configuration and use redirect servers and serverfarms instead of the normal servers. The user's would be loadbalanced to the respective serverfarms based on source IP and redirected to the URL's you would like.
Kanwal
Note: Please mark answers if they are helpful.
