Cisco ACE loadbalancing matching more than one header in L7 class map
abhisar patil
Dear All,
This is regarding Cisco ACE loadbalancing matching more than one header in L7 class map. I have a small setup with ACE 30 module in Cisco6500. I have got three webservers. Presently I have following configuration where I am mathing one url header.
class-map type http loadbalance match-all L7_WEB_HEADER_MATCH
description MATCH THE HOST HEADER OF HTTP REQUEST
2 match http header Host header-value ".*abhisar.com*"
So for above configuration, when traffic is coming for abhisar.com, it is working fine.
Now, I have following headers and DNS entry is pointing to same virtual IP for all http url header same as abhisar.com
abhisarindia.com
indiaabhi.com
So new configuration will be
class-map type http loadbalance match-any L7_WEB_HEADER_MATCH
4 match http header Host header-value ".*abhisarindia.com*"
6 match http header Host header-value ".*indiaabhi.com*"
So just want to confirm if this is fine.
Thank You,
Abhisar.
rajsures
Hi Abhisar,
The class-map configured looks fine to match as per your criteria.
Rajesh.
Dear Rajesh,
Thank you for reply. I will let you know once I carry out this activity.
Thank You,
Abhisar.
