Cisco ACE SSL Offloading not working
Dear All,
  I have configured SSL  offloading on ACE when i tried to test it from the PC i found that:
1. when i try to test the SSL Offloading by   (https://192.168.69.110)  i can reach the main page on WEB1 but i can't open any virual directory or any link inside this server (ex: https://192.168.69.110/web).
Bader
Jorge Bejarano
Level 4
Level 4
Hello Mohammed,
The behavior which you are getting is totally expected since you are NOT matching the url.
Why do not you try this?
(config-cmap-http-lb)# class-map type http loadbalance match-all MATCH-URL
(config-cmap-http-lb)# match http url /.*
  2 match http url /.*
Also you can try this one instead of the one above, since this one will be more specific:
  2 match http url /web.*
policy-map type loadbalance first-match WEB-SERVERS-LB
class MATCH-URL
    sticky-serverfarm Sticky-WEB-SERVERS
class class-default
Please mark it, if it fixes your issue.
Jorge
Jorge Bejarano
Level 4
Level 4
Hello Mohammed,
class MATCH-URL
class class-default
Jorge
Hi Jorge,
Today i applied the commands and every thing is working fine.
thanks for assistant and appreciated.
Hey Mohammed,
I am glad to hear that, It sounds great!!!
Jorge
