Cisco CSS loadbalancing issue
Tapan_Sheth
Community Member
                I am having Cisco CSS 11506 and have configured the following commands on it:-
flow-timeout-multiplier 12,
advanced-balance sticky-srcip &
sticky-inact-timeout 480
for a particular VIP but the CSS is not doing Load Balancing on the physical servers connected below as defined in the service.
The load balancing happens when i remove the above three commands.
Kindly help resolve the issue as i have to keep the above commands and yet do load balancing???
Jorge Bejarano
Level 10
Level 10
Hi Tapan,
Can you upload the rest of the configuration ?
Are you doing any NAT process?(groups)
Has this ever worked before?
Are you able to ping/telnet the servers from the CSS?
What is the default gateway of the servers? Can you ping the CSS from the servers?
Jorge
