Cisco ACE SSL Offloading not working
Mohammed Rahim Humide
Frequent Visitor
Frequent Visitor
Dear All,
  I have configured SSL  offloading on ACE when i tried to test it from the PC i found that:
1. when i try to test the SSL Offloading by   (https://192.168.69.110)  i can reach the main page on WEB1 but i can't open any virual directory or any link inside this server (ex: https://192.168.69.110/web).
Bader
Jorge Bejarano
Level 10
Level 10
Hello Mohammed,
The behavior which you are getting is totally expected since you are NOT matching the url.
Why do not you try this?
(config-cmap-http-lb)# class-map type http loadbalance match-all MATCH-URL
(config-cmap-http-lb)# match http url /.*
  2 match http url /.*
Also you can try this one instead of the one above, since this one will be more specific:
  2 match http url /web.*
policy-map type loadbalance first-match WEB-SERVERS-LB
class MATCH-URL
    sticky-serverfarm Sticky-WEB-SERVERS
class class-default
Please mark it, if it fixes your issue.
Jorge
Jorge Bejarano
Level 10
Level 10
Hello Mohammed,
class MATCH-URL
class class-default
Jorge
Hi Jorge,
Today i applied the commands and every thing is working fine.
thanks for assistant and appreciated.
Hey Mohammed,
I am glad to hear that, It sounds great!!!
Jorge
