Cisco ACE transparent serverfarm with http
florentDet
I use ACE for load balance www and https to 3 servers. I use mode transparent for keep destination address and match it on each firewall (like failover).
For test, I tried on one server:
   Me (194.78.223.33)
Internet
     | (vlan 1231)
  ACE
     | (vlan 2164)
Firewall
Nginx (192.168.23.31)
Configuration:
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
probe tcp PROBE_TCP
  interval 5
  passdetect interval 10
rserver host i1
  ip address 172.16.0.1
  conn-limit max 50000 min 40000
  inservice
serverfarm host FARM_WEB_SSL
  transparent
  predictor hash address destination 255.255.255.255
  probe PROBE_TCP
  rserver i1
    inservice
class-map match-any L4-WEB-SSL-IP
  2 match virtual-address 5.135.79.20 tcp eq https
  3 match virtual-address 5.135.79.20 tcp eq www
policy-map type loadbalance http first-match WEB_SSL_L7_POLICY
  class class-default
    serverfarm FARM_WEB_SSL
    insert-http x-forward header-value "%is"
policy-map multi-match LB-to-vIPs
  class L4-WEB-SSL-IP
    loadbalance vip inservice
    loadbalance policy WEB_SSL_L7_POLICY
access-group input ANY
interface vlan 1231
  ip address 5.135.79.26 255.255.255.240
  alias 5.135.79.25 255.255.255.240
  peer ip address 5.135.79.27 255.255.255.240
  service-policy input REMOTE_PUBLIC_MGMT
  service-policy input LB-to-vIPs
  no shutdown
interface vlan 2164
  ip address 172.31.255.250 255.240.0.0
  alias 172.31.255.249 255.240.0.0
  peer ip address 172.31.255.251 255.240.0.0
  no normalization
  mac-sticky enable
  no icmp-guard
  nat-pool 1 172.31.255.248 172.31.255.248 netmask 255.240.0.0 pat
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
ft track interface VLAN1231
  track-interface vlan 1231
  peer track-interface vlan 1231
  priority 50
  peer priority 5
ip route 0.0.0.0 0.0.0.0 5.135.79.30
My proxy sever recive request :
11:23:12.027868 IP (tos 0x0, ttl 254, id 26864, offset 0, flags [none], proto TCP (6), length 44)
    194.78.223.33.53120 > 192.168.23.31.http: Flags [S], cksum 0x90ef (correct), seq 2632425798, win 32768, options [mss 1460], length 0
E..,h........N.!.......P...F....`...........
11:23:12.027884 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
    192.168.23.31.http > 194.78.223.33.53120: Flags [S.], cksum 0xa64f (correct), seq 556994644, ack 2632425799, win 14600, options [mss 1460], length 0
E..,..@.@........N.!.P..!3.T...G`.9..O......
11:23:12.548061 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
   192.168.23.31.http > 194.78.223.33.53018: Flags [S.], cksum 0x2225 (correct), seq 2696932208, ack 1878390816, win 14600, options [mss 1460], length 0
E..,..@.@........N.!.P.....po.. `.9."%......
But nothing in access log ... I tried with web server too .. Nothing ...
If I try without ACE, it works.
ajayku2
I see that you have tried to create a nat pool but I dont see any policy that use it.
  class L4-WEB-SSL-IP
    nat dynamic 1 vlan 2164  << Missing >>
try using the same that should help.
Also refer the following for more troubleshooting tips
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Troubleshooting_Guide_--_Troubleshooting_Network_Address_Translation#Configuring_Dynamic_NAT_and_PAT
regards,
Ajay Kumar
ajayku2
  class L4-WEB-SSL-IP
regards,
Ajay Kumar
Thank you for the answer
Now, I've :
class L4-WEB-SSL-IP
But the result is the same... With IP of ACE
15:02:49.730291 IP (tos 0x0, ttl 254, id 713, offset 0, flags [none], proto TCP (6), length 44)
    172.31.255.248.menandmice-mon > 192.168.23.31.http: Flags [S], cksum 0xabc8 (correct), seq 410041845, win 32768, options [mss 1460], length 0
E..,......6#...........P.p......`...........
15:02:49.730305 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
   192.168.23.31.http > 172.31.255.248.menandmice-mon: Flags [S.], cksum 0xd2f5 (correct), seq 2554169212, ack 410041846, win 14600, options [mss 1460], length 0
E..,..@.@............P...=.|.p..`.9.........
15:02:50.930111 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
15:02:52.713523 IP (tos 0x0, ttl 254, id 8483, offset 0, flags [none], proto TCP (6), length 44)
E..,!#.................P.p......`...........
15:02:52.713552 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
15:02:52.930118 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
15:02:56.930124 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
15:02:58.693106 IP (tos 0x0, ttl 254, id 23582, offset 0, flags [none], proto TCP (6), length 44)
E..,\..................P.p......`...........
15:02:58.693122 IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 44)
Let me clarify the issue.
1) The load balancing is not working ?
or
2) x-forward is not getting inserted ?
Also just for clarity :
If you do not want the ACE to use NAT to translate the VIP to the server IP address, enter:
host1/Admin(config-sfarm-host)# transparent
So in above case ACE will forward the request to mac address of the server with VIP ip address as destination.
If you issue command :
switch/C1#show stats http
You will notice this counter increasing if x-forward is being inserted. Plus the server should be enabled to read x-forward.
Headers inserted          : 10
So far my understanding is you are unable to see any access log on the proxy or server.
regards,
Ajay Kumar
It works !
Except in server 1 ... My 3 servers have exactly the same config. But server 1 continue to not respond
These are 3 servers Proxmox.
Headers inserted          : 30516
Thanks for all
