Cisco nexus 5020 OS upgrade failed.
atif.shadab
Hi All,
I have cisco 5020 nexus switch which is currently running with
kickstart: version 4.0(0)N1(2)
system:    version 4.0(0)N1(2)
I want to upgrade for
kickstart: version 4.2(1)N2(1)
system:    version 4.2(1)N2(1)
i believe it requires chain upgrade , hence i tried going for immediate next versions and also tried required version
4.0.1a.N2.1
4.0.1a.N1.1a
4.2.1.N2.1
But whenever i upload images and verify by giving
show install all impact kickstart bootflash:n5000-uk9-kickstaart.4.0.1a.N1.1a.bin system bootflash:n5000-uk9.4.0.1a.N1.1a.bin
i get the following error.
Verifying image bootflash:/n5000-uk9-kickstart.4.0.1a.N1.1a.bin for boot variabl
e "kickstart".
[#                   ]   0%[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.4.0.1a.N1.1a.bin for boot variable "system"
Verifying image package type.
[#                   ]   0%[#####               ]  20%[####################] 100% -- SUCCESS
Extracting "system" version from image bootflash:/n5000-uk9.4.0.1a.N1.1a.bin.
[#                   ]   0%[#                   ]   0% -- FAIL. Return code 0x404F0003 (SRG file not presen
t/cannot be opened).
Version Compatibility check failed. Return code 0x40930012 (SRG extraction failed).
Please help in getting this issue solve.
Atif
5 Replies 5
I have the same problem with a Nexus 7000. I have the version 5.1.1a, and I want to upgrade to 5.2.7, and I have the same fail when I try to make the "show install all impact".
Can anyone tell me whan can i do?
I get this:
show install all impact kickstart bootflash:n7000-s1-kickstart.5.2.7.bin system bootflash:n7000-s1-dk9.5.2.7.bin
Verifying image bootflash:/n7000-s1-kickstart.5.2.7.bin for boot variable "kickstart".
Verifying image bootflash:/n7000-s1-dk9.5.2.7.bin for boot variable "system".
Verifying image type.
Extracting "lc1n7k" version from image bootflash:/n7000-s1-dk9.5.2.7.bin.
[#                   ]   0% -- FAIL. Return code 0x404F0003 (SRG file not present/cannot be opened).
Extracting "bios" version from image bootflash:/n7000-s1-dk9.5.2.7.bin.
Extracting "system" version from image bootflash:/n7000-s1-dk9.5.2.7.bin.
Extracting "kickstart" version from image bootflash:/n7000-s1-kickstart.5.2.7.bin.
Pre-Upgrade check failed. Return code 0x40930012 (SRG extraction failed).
A show version:
Software
  BIOS:      version 3.22.0
  kickstart: version 5.1(1a)
  system:    version 5.1(1a)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.5.1.1a.bin
  kickstart compile time:  12/25/2020 12:00:00 [11/05/2010 00:14:37]
  system image file is:    bootflash:///n7000-s1-dk9.5.1.1a.bin
  system compile time:     11/4/2010 11:00:00 [11/05/2010 01:25:15]
Thanks in advance
HI All,
You guys are hitting the following bug:
CSCsw25835
This bug is because everytime you telnet we are creating files called "sup_params_info" in the /var/tmp
directory. So over time there might be thousands of files after you telnet many times into the N5k. You
can confirm if you are hitting this bug by issuing "show system internal dir /var/tmp" and seeing
thousands of files called "sup_params_info".
Workaround:
Reload device to clear out temporary files before running install routine.
REgards
Inayath
*Plz rate all usefull postzs
Inayath,
PM sent.
Thanks Inayath!
