Script on ACE to do a packet capture during probe failure
Hi All,
I'm working on troubleshooting Intermittent application access. probe was getting failed intermittently.
Is it possible to run any script on ACE which will do the packet capture only if the probe failed to an application?
Thiyagu
Jorge Bejarano
Level 4
Level 4
Thiyagu,
The ACE was not designed to run captures( at least not at high level as a NAM for example) then the traces which we can take in the ACE does not capture neither probe traffic nor management traffc only load balancing traffic.
TAC does not support customized scripts.
If you need to check how the probes are behaving then you may need to run a simultaneous capture on the client PC and the server itself or if you have an ACE module then you can run a 10giga capture.
Jorge
