CiscoView for CSM
mslagel
Setup things according to the install doco.
did:
installed s/w properly on disk0:
enabled http
ip http path disk0:
However, when I open a browser to the ip address, I get not but no page found.
If I telnet to the ip address and port 80, I get a response so I know the webserver is running. The software is loaded to the / directory. I see a cv directory with files in it, and two othfiles at the / level.
home.html
home.shtml
Things seem right but no login prompt ever comes up?
6 Replies 6
Gilles Dufour
did you install ciscoview for the catalyst as well ?
If I remember correctly, you access the CSM via the catalyst pages.
So are you able to view the cat6k ?
Gilles.
I did install it yes. However, it is not a requirement. I will check on the second part of your question. Thanks for the reply.
ok - just tried it and it works.
ip http server
ip http authentication local
ip http path disk0:
And it works.
Did you configure the correct path ?
Also, if you want to access the csm module directly, the correct url is this
http:///flash/cv/applet.html?dynarchives=cvdm-csm-1.0.sgz&sl
otNo=
Where is the IP address of the switch and is the slot
number where CSM resides.
Otherwise, the default url is the Cat6k CVDM and from there you can select the CSM.
Gilles.
you mentioned "did you configure the correct path". I have the three ip statements as you have. I tried you direct url and same thing. No page found
I have CVDM loaded also. If i point to the ip address, "no page found". In the / directory of disk0: is a cv directory, and two home.x files.
Note: I never get the login prompt either
finally get a login prompt. (not enough vty's).
Now things start to work but I am getting javascript errors....
