CMA not sync changes of SSL changes.
Jan Rockstedt
Last week i did an change of our SSL Accelerated Services.
I change the service address from ip to host address for two services as this an new feature in 4.2.x
Some of our WAE's have the new config of SSL and some have the old config of SSL.
I have tried with one WAE to run cms dereg and cms enable without success, same problem.
I use 4.2.3b on the CMA and 4.2.1 on the WAE.
How do I fix this problem?
Jan Rockstedt
Jan Rockstedt
I have reload my CMA now.
Now the Central Manager's secure store is initialized but not opened
I will open it again, but why is it not open after reload?
Jan
Hi Jan,
Secure store is not automatically opened after a reboot because it requires the password you used to create it. Having to manually supply the password after a reload is a security measure.
Daniel
Hi Daniel,
Ok so that is not an issue.
I guess i have only rebooted the CMA a few times.
But I still have an issue with the SSL and the changes that is not going over to WAE.
Jan
Hi Jan,
Giving you a straight answer for that answer will not be so easy, so, you should consider opening a TAC service request to have it investigated further.
