Showing results forĀ
Search instead forĀ
Did you mean:Ā
cms recover issue with the WAE-612
SK Ameen .
Hi ,
We are getting the erorr  in the attached fille when we entered the command "cms recover identity" on the new WAE-612 install with the working hard disks( from the faulty WAE-612).
The WAAS OS on the flash is 4.0.9 and on the disk based software is 4.3.3
Please advice how to recover the exsisting config on the new WAE from the WAAS CM.
Ameen,
The disk based software and the software on the flash must match.
I suggest you use the recovery CD to install the proper system image on the flash.
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/waas/waas/v431/configuration/guide/maint.html#wp1173532
Once the system image matches the image installed on disk you can then try again to recover the identity.
Mike Korenbaum
Cisco Data Center PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
