CMS status is offline. WAVE 274 appears offline but it is telnetable
rach_rach_hunt
Hi all ,
One of my WAVE-274 has this alarm :
It appears offline on the central manager GUI but it is reachable by Telnet . This is the message I get when logging :
System Initialization Finished.
Disk based software not installed.
Some applications may not run correctly!
WAVE-274#
Any idea how to precede ?
Software version 4.1.3b
Felix Arrieta
Hi Rach,
Please get the following output: WAVE# show disks details
regards,
Felix
WAVE-274#sh disk details
Physical disk information:
  disk00: Present    WD-WCAT1D394405    (h00 c00 i00 l00 - Int DAS-SATA)
          239421MB(233.8GB)
  disk01: Not present or not responding
Mounted file systems:
MOUNT POINT      TYPE       DEVICE                SIZE     INUSE      FREE USE
/sw              internal   /dev/sda1            991MB      16MB     975MB   1
/swstore         internal   /dev/sda2            991MB      16MB     975MB   1
/state           internal   /dev/sda3           5951MB     130MB    5821MB   2
/local/local1    SYSFS      /dev/sda6          11903MB     610MB   11293MB   5
/vbspace         GUEST      /dev/data1/vbsp    59515MB     128MB   59387MB   0
.../local1/spool PRINTSPOOL /dev/data1/spool     991MB      32MB     959MB   3
/obj1            CONTENT    /dev/data1/obj    101177MB     128MB  101049MB   0
/dre1            CONTENT    /dev/data1/dre     39677MB     128MB   39549MB   0
/ackq1           internal   /dev/data1/ackq     1189MB      32MB    1157MB   2
/plz1            internal   /dev/data1/plz      2379MB      65MB    2314MB   2
No RAID devices present.
Disk encryption feature is disabled.
WAVE-274#
swinters
this eror message means that WAAS software is not fully installed on the WAVE device (I'm not sure I understand how the CM can have the device's information while the device isn't completely installed.) When installing WAAS from CD, there are several menu options you ned to select (I forget the exact number sequence: 1,3,5,7,8) where the last option is to install the WAAS image from CD then exit, unload the CD and reload.
I've ran across similar erorr message as yours when I forgot to follow the last two steps (and hence didn't install WAAS system image)
Is this a new install, or has this WAVE 274 been operational for a while?
In fact I'm not the one who installed the software . But i can tell you  this is an old install and was fully operationnal.
regards,
