commitVipRedundancy with ASR
savyer
Level 2
Level 2
Is it expected behavior when commitVipRedundancy is being run on active CSS in ASR mode, the active CSS doesn't accept new connections and backup can't be reached via telnet/ssh? When command is completed CSS resumes accepting and switching new connections.
(tested with 7.50)
wong34539
Level 11
Level 11
Yes. This is the accepted behaviour. When this command is executed on the active CSS in the ASR mode, the active CSS will not accept new connections.
What's the reason of that behavior? Is there any way to allow new connecitons during a config sync?
Also, is Standby being inaccessible remotely acceptible behavior as well?
