Cisco AVS Flash Forwarding not working
m.baker2
Hi everyone,
We tryed without any success to get Cisco AVS 3110 FlashForwarding to work. We configured the default application classes for Flash forwarding, published config and restarted the appliance. No luck. ANy idea what could prevent Flash forwarding from Working ? I notice an header coming from our server with no-cache,no-store directive. Could that cause the problem ? If so, how do I get the appliance to override this ? Also, we are not able to get the appliance to log information to FgnStatLog so we can debug this. Is there a specific flag for LogLevel we ned to use for the logging to work properly. Our config is as follows ;
CacheDepth 4
Include "conf/useragent.conf"
Include "conf/mimetypes.conf"
CompressContent On
DeltaOptimize On
BaseFileCompress Off
CompressionMethod deflate
BaseFileCompressionMethod deflate
HTTP10Compress On
CacheRoot "/usr/local/fineground/perfnode/cache"
CachePruner Off
CacheSize 500000
CacheFanout 10
ConnectionReuse KeepAlive
LogDir "/usr/local/fineground/perfnode/logs"
CachePruneSampleSize 30
CachePruneKeepSize 5
FgnWorkDir "/usr/local/fineground/perfnode/workdir"
AppScope On
AppScopeOptimizeRatePercent 50
AppScopePassThruRatePercent 50
UrlMatchWithProtocol On
AppScreen Off
ExcludeNonASCII On
FgnNamePrefix fgn_
DNSTimeout 36000
RebaseDeltaPercent 50
CacheMinTTL 0
CacheMaxTTL 60
<ApplicationClass fgnpost>
Url "^.*/fgn_post\.html$"
Url "^.*/fgn_nopost\.html$"
Url "^.*/fgn_dbgtrace.*\.js$"
Url "^.*/fgn_appscope.*\.js$"
OptimizationPolicy NoDeltaOptimize,NoCompress,NoFlashForward
AppScope Off
</ApplicationClass>
<ApplicationClass DefaultFlashForward>
Url "^.*\.gif$"
Url "^.*\.css$"
Url "^.*\.js$"
Url "^.*\.class$"
Url "^.*\.jar$"
Url "^.*\.cab$"
Url "^.*\.txt$"
Url "^.*\.ps$"
Url "^.*\.vbs$"
Url "^.*\.xsl$"
Url "^.*\.xml$"
Url "^.*\.pdf$"
Url "^.*\.swf$"
CacheMinTTL 0
CacheMaxTTL 60
OptimizationPolicy FlashForwardObject,NoCompress,NoDeltaOptimize
ResponseCachePolicy OverrideAll
</ApplicationClass>
<ApplicationClass DefaultFFWithImageOpt>
Url "^.*\.jpg$"
Url "^.*\.jpeg$"
Url "^.*\.jpe$"
Url "^.*\.png$"
CacheMinTTL 0
CacheMaxTTL 60
ImageOptimization Standard
</ApplicationClass>
<ApplicationClass DefaultCompress>
Url "^.*\.html$"
Url "^.*\.htm$"
OptimizationPolicy Compress,FlashForward,MetaRefreshTo302
</ApplicationClass>
<ApplicationClass DefaultClass>
Url "^.*$"
</ApplicationClass>
<AppScreenClass DefaultAppScreen>
Url "^.*$"
AppScreenPolicy nullByte | Pass
AppScreenPolicy script | Pass
AppScreenPolicy sql | Pass
AppScreenPolicy directoryTraversal | Pass
AppScreenPolicy binary | Pass
AppScreenPolicy prohibitedFileUpload | Pass
</AppScreenClass>
pradeepde
Level 5
Level 5
Put "ResponseCachePolicy OverrideAll" in ApplicationClass DefaultFFWithImageOpt should solve this problem. As the web server
inserts 'no-cache/no-store' for jpg/gif objects, this 'overrideall' policy can ignore these response headers and cache the objects still.
