configure SSL for virtual web
julxu
Is it possible to achive the following:
-myhost is a web server.
-myweb1 is a virtual web located on myhost, so, it is an DNS alias of myhost. it's SSL runs on the server myhost.
-myhost2 is another virtual web located on myhost and it is an DNS alias of myhost also. it has another key/cert and run SSL on the server myhost also.
I have been asked to configure SSL termination on my CSS11506 to offload the SSLs trafic.
Could anyone advice me for a VIP, (myhost), can I use two key/CA? if so, how do I configure them?
Any comments will be appreciated
Thanks in advance.
Gilles Dufour
The problem is that a key/cert pair is associated with 1 domain only [or multiple domains if you have wildcard certificate - but it's obviously not the case here].
When the CSS receives the TCP SYN to initiate a new SSL connection, it does not know which domain, because 1 ip belongs to 3 domains.
Therefore the only solution to identify which domain it is [and therefore which key/cert to use], is to use a different TCP port for each domain.
myhost would use port 443
myweb1 would use port 444
myweb2 would use port 445
This is usually not very good because most of the time you never specify the port in your browser. So, you may type https://www.myweb1.com and end up at https://www.myhost.com because the default port is 443.
Since this is a new design I would strongly recommend to have 1 IP address per domain.
This is not a Cisco limitation but a TCP/IP behavior.
Gilles.
7 Replies 7
Gilles Dufour
Gilles.
do you mean give myhost two vip? so:
myhost:
VIP 10.1.30.31 - dns name myhost1,dns alias myweb1
VIP 10.2.30.32 - dns name myhost2,dns alias myweb2
Many Regards
I have make two VIPs and they all use same service - the local server of myhost.
configured DNS as above. and after client send client hello, the VIP send res ack. (both sites)
Am I configure wrong? the configuration just looks same as others.
Any advice?
Thanks in advance.
give us your full config.
If you are using 2 vip addresses, I don't see where is the problem.
Simply configure the 2vips, the 2 ssl-server and use the same service for the backend connection.
Gilles.
ssl-proxy-list ssl-slot3
ssl-server 31
............. -> the one which working fine.
ssl-server 14
ssl-server 14 vip address 10.1.31.14
ssl-server 14 cipher rsa-with-rc4-128-sha 10.11.31.14 81
ssl-server 14 rsakey Myweb1Rkey
ssl-server 14 rsacert Myweb1Scert
ssl-server 15
ssl-server 15 vip address 10.1.31.15
ssl-server 15 rsakey Myweb2Rkey
ssl-server 15 rsacert Myweb2Scert
ssl-server 15 cipher rsa-with-rc4-128-sha 10.11.31.15 81
active
service ssl-slot3-srv
type ssl-accel
keepalive type none
slot 3
add ssl-proxy-list ssl-slot3
active
service myhost
ip address 10.4.31.14
keepalive type tcp
keepalive port 80
active
owner mytest
content myweb2-rule
add service ssl-slot3-srv
protocol tcp
port 443
content myweb2-rule2
vip address 10.4.31.15
protocol tcp
port 81
balance leastconn
add service myhost
active
content myweb1-rule
protocol tcp
port 443
active
Do I miss anything?
sorry, miss the last part:
content myweb1-rule2
port 81
protocol tcp
add service myweb1
balance leastconn
active
yes, it is working now.
