Connection gets dropped exactly after 5 minutes for the application hosted behind ACE 4710
Saroj Pariyar
Hi Guys,
I am going through some strange issue.There is one application hosted behind Cisco ACE 4710 and when application team try to access the application the connection gets dropped exactly after 5 minutes.But when they try to access the application directly through the server(bypassing the cisco ACE) the connection doesnot get dropped.The configuration is pretty straightforward,nothing fancy.if anyone has faced this similar issue before with Cisco ACE 4710 Please let me know.
probe tcp TCP_8101
  port 8101
  interval 10
  faildetect 5
  passdetect interval 40
  open 1
class-map match-all app_ASPEN_DCT_PREProd_class
  2 match virtual-address x.x.x.x tcp eq https
serverfarm host app_ASPEN_DCT_PREProd
  probe TCP_8101
  rserver servername1 8101
    inservice
  rserver servername2 8101
    inservice
policy-map type loadbalance first-match app_ASPEN_DCT_PREProd_policy
  class class-default
    serverfarm app_ASPEN_DCT_PREProd
policy-map multi-match POLICY-LB-VLAN488
class app_ASPEN_DCT_PREProd_class
    loadbalance vip inservice
    loadbalance policy app_ASPEN_DCT_PREProd_policy
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 488
7 Replies 7
sivaksiv
The default inactivity timeout are as
follows: TCP:3600sec UDP:120secs ICMP:2sec
These are inactivity timeouts, meaning if the connections are idle for these many seconsds then the connection will be dropped.
If you need a different TCP timeout value, you can change it using the follwoing example
To change TCP idle timeout to 5 minutes
parameter-map type connection TCP-PARAM
set timeout inactivity 300
class-map match-all TCP-CLASS
match port tcp any
policy-map multi-match VIP
class TCP-CLASS
connection advanced TCP-PARAM
Siva
Hi Siva,
As per the cisco document,
Starting with software  version A4(1.0), the default connection inactivity timeout settings for  the ACE have changed to the following values:
ICMP—2 seconds
TCP—3600 seconds (1 hour)
HTTP/SSL—300 seconds
UDP—10 seconds
How to increase the HTTP/SSL default timeout value of 300 Second to more ?? I tried to increase the timeout value for HTTP/SSL only,but ACE doesnot have any option
nuspthtestlds001/Admin(config-parammap-conn)# set timeout inactivity ?
  <0-3217203>  Inactivity (TCP 3600, HTTP/SSL 300, UDP 10, ICMP 2)
If i set value let's say 500 does it apply for all TCP,HTTP/SSL,UDP and ICMP.
Please suggest.
Hi Saroj,
If you are running 5.x then you also have a option to add the parameter map globally.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA5_1_x/release/note/ACE_mod_rn_A51x.html
read section :
Globally Applying Parameter Map Inactivity and TCP Half-Closed Connection Timeout Values
If you want to apply it for specific VIP then you should apply as follows:
parameter-map type connection connection_pm
  set timeout inactivity 600
serverfarm host TEST_SERVERFARM
probe TCP-80-PROBE
rserver TEST 80
inservice
class-map match-all TEST_CM
2 match virtual-address 10.72.54.19 tcp eq  80
policy-map type loadbalance first-match TEST-PM
   class class-default
     serverfarm TEST_SERVERFARM
class TEST_CM
loadbalance policy TEST-PM
connection advanced-options connection_pm
Hope that helps.
regards,
Ajay Kumar
Hi Ajay,
Appreciated your quick response
Will it change HTTPS inactivity timeout too ??? or will this change TCP inactivity timeout. For my issue i need to change the HTTPS timeout inactivity timeout. Could you please suggest how to do that ??
Hi Saroj,
Before applying the parameter  map :
ace30/Admin# sh parameter-map CONN
Parameter-map : CONN
Description : -
Type : connection
    nagle                              : disabled
    slow start                         : disabled
    buffer-share size                  : 32768
   inactivity timeout (seconds)       : TCP: 3600, UDP: 10, ICMP: 2, HTTP/SSL: 300
    reassembly timeout (seconds)       : 60
    embryonic timeout (seconds)        : 5
    ack-delay (milliseconds)           : 200
    WAN Optimization RTT (milliseconds): 65535
    half-closed timeout (seconds)      : 3600
    fast FIN timeout (seconds)         : disabled
    TOS rewrite                        : disabled
    syn retry count                    : 4
    TCP MSS min                        : 0
    TCP MSS max                        : 1460
    tcp-options drop range             : 0-0
    tcp-options allow range            : 0-0
    tcp-options clear range            : 1-255
    selective-ack                      : clear
    timestamp                          : clear
    window-scale                       : clear
    window-scale factor                : 0
    reserved-bits                      : allow
    random-seq-num                     : enabled
    SYN data                           : allow
    full-proxy-mss-mismatch            : disabled
    exceed-mss                         : drop
    urgent-flag                        : allow
    conn-rate-limit                    : disabled
    bandwidth-rate-limit               : disabled
ace30/Admin#
After applying the parameter map :
ace30/Admin(config)# parameter-map type connection CONN
ace30/Admin(config-parammap-conn)# set timeout inactivity 600
ace30/Admin(config-parammap-conn)# end
ace30/Admin#
Description : -
Type : connection
    nagle                              : disabled
    inactivity timeout (seconds)       : 600  <<< You will notice that the value has changed for all
    syn retry count                    : 4
    TCP MSS min                        : 0
    TCP MSS max                        : 1460
    timestamp                          : clear
    SYN data                           : allow
    exceed-mss                         : drop
    urgent-flag                        : allow
So to answer your question the suggested changes will change timeout for HTTPS inactivity timeout also.
regards,
Ajay Kumar
Is there anyway to increase JUST the http/ssl portion.
What I would really want is to change:
to
inactivity timeout (seconds)       : TCP: 3600, UDP: 10, ICMP: 2, HTTP/SSL: 1800
This is how you apply timeouts for http connections
policy-map multi-match HTTP
  class HTTP
    connection advanced-options HTTP
class-map match-any HTTP
  2 match port tcp eq www
parameter-map type connection HTTP
  set timeout inactivity 1200
Then apply this service-policy globally or in the interface from where the traffic is
coming in
