Couldn't bring up a switch Port-channel connecting to WAVE-574
gwhuang5398
Level 2
Level 2
I'm connecting WAVE-574's two GigE ports to two GigE ports on the switch. The WAVE-574 is running WCCP (the inline adapter is not in use). Two switch ports are in a Port-channel, and two WAVE-574 ports are also configured in Port-channel. I have tried "auto/auto" on those ports, and "1000 full" too. Either case, the port-channel interface on the switch is always "down down", while both switch ports are "up up", and the WAVE-574 Port-channel and GigE ports are also showing up.
What can be the issue here? I have used the same config on between a WAE-674 and a 10/100 switch, the port-channel on the switch is just fine.
Here are the configs:
Switch#
interface Port-channel1
description To WAVE-574
switchport
switchport access vlan 100
switchport mode access
spanning-tree portfast
interface GigabitEthernet3/12
channel-group 1 mode desirable
interface GigabitEthernet3/13
WAVE-574#
primary-interface PortChannel 1
description To Switch Port-channel 1
ip address 192.168.100.10 255.255.255.0
exit
interface GigabitEthernet 1/0
description To Switch Gi3/12
channel-group 1
exit
interface GigabitEthernet 2/0
description To Switch Gi3/13
channel-group 1
exit
Thanks in advance
Gary
dstolt
Gary,
Did you figure this one out? If not, I would open a TAC case on this one. It all looks good to me. The WAE interfaces should be auto for Gig-E.
Dan
Hi Dan:
Thanks for the reply. I have not made it work yet. I have tried setting ports to auto-sensing or static "1000, full-duplex". Either case, the switch port-channel is "down down", while the WAE port-channel is shown as "UP".
Right now, looks like only one GigE port in the channel is actually carrying traffic.
If you can help me out on this, that'll be great.
Thanks again
Gary
