How to resolve "max_conn_overload" alarm from WAE-674 in WCCP mode?
gwhuang5398
Level 2
Level 2
I have a WAVE-574 and a WAE-674 showing the minor alarm "max_conn_overload: The TFO accelerator is overloaded (connection limit)". Both are running WCCP redirection.
From CM GUI > Dashboard > Device > Monitor > Traffic Analysis > Connection Statistics, one device showed 175 connections and the other showed 864 connections. The alarm seems to say there's a limit of # of connections the TFO accerelator can handle. But how can I find the limit on the device? Is it configurable? What is the best practice to resolve this overload?
I have searched Cisco web sites for possible explanations, but couldn't find any.
Thanks in advance.
Gary
dstolt
Gary,
What version of WAAS are you running?
Dan
Hi Dan:
4.1.1c build 16 on all WAE and WAVE. All devices were ordered recently and shipped from Cisco within last a few weeks.
On the WAE, "sh statistics tfo" and "sh tfo detail" both show some numbers, but they don't seem to be corelated or match.
Thanks a lot
Gary
Gary,
There is a situation where routing loops can cause TFO overload and not show up in the stats (CSCsx68058). The stats/detection is fixed in 4.1.3, however the problems with routing loups still exist...
Look for errors in the syslog (opt_syn_rcv: Routing Loop
detected - Packet has our own devid. Packet dropped) or "sh stat TFO". See if you are seeing things like that which may be causing the TFO overload.
Dan
Hi Dan:
Thanks for the info. The TFO overload alarm was found on WCCP WAE and also Inline mode WAE. So probably not the routing loop issue. I looked at TFO stats, but not sure what numbers are good indications.
Can you take a look at the stats from the WCCP WAE-674?
Thanks a lot
Gary
WAE674-WCCP#sh stat tfo detail
Total number of connections : 10173
No. of active connections : 31
No. of pending (to be accepted) connections : 0
No. of bypass connections : 2216
No. of normal closed conns : 9587
No. of reset connections : 555
Socket write failure : 174
Socket read failure : 0
WAN socket close while waiting to write : 0
AO socket close while waiting to write : 0
WAN socket error close while waiting to read : 0
AO socket error close while waiting to read : 197
DRE decode failure : 0
DRE encode failure : 0
Connection init failure : 43
WAN socket unexpected close while waiting to read : 30
Exceeded maximum number of supported connections : 0
Buffer allocation or manipulation failed : 0
Peer received reset from end host : 106
DRE connection state out of sync : 0
Memory allocation failed for buffer heads : 0
Unoptimized packet received on optimized side : 5
Data buffer usages:
Used size: 0 B, B-size: 0 B, B-num: 0
Cloned size: 234 KB, B-size: 337 KB, B-num: 1230
Scheduler:
Queue Size: IO: 0, Semi-IO: 0, Non-IO: 0
Total Jobs: IO: 243894, Semi-IO: 215419, Non-IO: 29919
Policy Engine Statistics
Session timeouts: 0, Total timeouts: 0
Last keepalive received 00.1 Secs ago
Last registration occurred 7:22:30:06.9 Days:Hours:Mins:Secs ago
Hits: 4101731, Update Released: 67270
Active Connections: 2018, Completed Connections: 22638
Drops: 0
Rejected Connection Counts Due To: (Total: 4010359)
Not Registered : 0, Keepalive Timeout : 0
No License : 0, Load Level : 0
Connection Limit : 4010359, Rate Limit : 0
Minimum TFO : 0, Resource Manager : 0
Global Config : 0, TFO Overload : 0
Server-Side : 0, DM Deny : 0
No DM Accept : 0
Auto-Discovery Statistics
Connections queued for accept: 10146
Accept queue add failures: 0
AO discovery successful: 0
AO discovery failure: 0
