I am trying to setup 2 ACE in a FT mode. While both are active, I am all good
My questions are:
1) If I unplug the primary ACE Network cable, I loose connection to my HTTP servers (via VIP address) and my ping to the VIP failes, eventhough the second HTTP2 is still active. I guess since the FT connections between the 2 ACEs remain connected, it does not switch the the backup ACE.
2) I turned off HTTP1 Services on ACE1 and still when I try accessing the http using the VIP address, it still tries connect to HTTP1 hence I get message of page not found error. I tried setting up probe for HTTP but still it tries accessing the HTTP1.
