CSM and Firewall load balancing
drob
Does anyone have any practical experience using the CSM to load balance Checkpoint NG firewalls?
owillins
Level 6
Level 6
The CSM distributes traffic across multiple firewalls on a per-connection basis. Both stealth and standard firewalls are supported. I guess that Checkpoint NG would be supported too although I have no practical experience on it.
As per the configuration guide it is supposed to work. My concerns know is that it may be too complex to support in the long term. I am interested in success stories.
