CSM for enabling hot spare instead of load balancing
glenn.newman
We have a server at a remote site that we want the remote clients to use. We only want them to use the central server if the remote one fails. Is there a way I can use "weight" or some other method to accomplish this. Thanks.
Gilles Dufour
what device are you talking about ?
There is a solution but it is different depending of the machine you are using.
Gilles.
I am talking about a 6500 with Sup 720s and the CSM modules. The servers to be load balanced are Windows 2003 servers.
