CSM ft failover.
marcin.mazurek
is there any way to force faiover switch from standby to active after crash of active CSM module (preemption was off). I've seend in docs "ft active" command which is not available on CSM with 4.2(1) software.
Is there any wahy to switch from standby to active state except restarting module?
tia
Gilles Dufour
change the priority to make sure it has the highest priority and configure preempt.
It should take over.
Gilles.
Higher priority was set, I have configured after active CSM failure preempt on both modules, but it didn't take over anyway.
I have the same situation. Changed the priority, nothing happend.
Thanks.
It's fixed. It works while changing the priority but needs about 3mins to failover.
