CSM: Sticky timeout parameter: difference between sticky group and vserver
wim.juste
Concerning the example in the CSM manual about configuration of stickiness:
What (or why) is exactly the difference between the timeout parameter (100 minutes):
sticky 12 cookie foo timeout 100 AND the sticky 50 group 12 in the vserver.
The timeout parameter is overruled in the vserver configuration. (100 -> 50)
For what could this be usefull?
Thank you!
Kind regards,
Wim
This example shows how to configure a virtual server named barnett, associate it with the server farm
named bosco, and configure a sticky connection with a duration of 50 minutes to sticky group 12:
Router(config)# mod csm 2
Router(config-module-csm)# sticky 12 cookie foo timeout 100
Router(config-module-csm)# exit
Router(config-module-csm)# serverfarm bosco
Router(config-slb-sfarm)# real 10.1.0.105
Router(config-slb-real)# inservice
Router(config-slb-real)# exit
Router(config-slb-sfarm)# vserver barnett
Router(config-slb-vserver)# virtual 10.1.0.85 tcp 80
Router(config-slb-vserver)# serverfarm bosco
Router(config-slb-vserver)# sticky 50 group 12
Router(config-slb-vserver)# inservice
Router(config-slb-vserver)# exit
Router(config-module-csm)# end
Gilles Dufour
if you configure the group under a policy, there is no option for the timeout.
This is why the option exist under the stick-group.
In the vserver, you can overrid this timeout - so the timeout is per vserver.
If you want the same timeout, just configure the same value.
gdufour-cat6k-2(config-module-csm)#policy test1
gdufour-cat6k-2(config-slb-policy)#sticky-group ?
<1-255> sticky group ID
gdufour-cat6k-2(config-slb-policy)#sticky-group 12 ?
Gilles.
Gilles Dufour
Gilles.
