CSM Total conn failures
mruuth
With command "sho mod csm x real sfarm yyyy detail"
there is a counter for Total conn failures. In what situation is this counter incremented?
Mats
Gilles Dufour
server did not respond or server responded with a RESET.
Gilles.
Hi Gilles,
I'm also seeing this counter incrementing in our CSM. Is there any way on the CSM, to check the connections that got the RESET or not being answered by the real servers?
Thanks.
Pedro Almeida
not really.
The only solution is to capture a sniffer trace on the server showing the problem.
Gilles.
