CSM vserver ping problem
rraja2006
Community Member
When I create a vserver with type "any" I am unable to ping the vserver. That is, the following virtual server IP cannot be pinged.
vserver xyz
virtual a.b.c.d any
serverfarm xyz
inservice
But the following one can:
vserver xyz
virtual a.b.c.d tcp www
serverfarm xyz
inservice
Is there any workaround? I have tried using the VSERVER_ICMP_ALWAYS_RESPOND 1. But that does not fix it.
Raja
gaojianwen
Community Member
Raja,
Does your server's firewall block the ICMP packets?
Rgds,
Jianwen
bayoucisco
Community Member
using any the icmp request will be sent to the real server (as you loadbalance every protocol)
using www the icmp request will be proceed directly by the loadbalancer
So if your server can't reply to the icmp it is possible that when using any you won't have any response.
