CSS 11501 using wildcard certificates
comunicacoes
Community Member
I'm about to switch to wildcard certificates in a CSS 11501, however there are some doubts that I would like to clarify:
- When generating the CSR can i use *.mycompany.com for CN ?
- Should the CSR be generated only once or every time i need to create a new content rule i need to generate it?
     - If only once can I associate multiple filenames with only one certificate?
          ssl associate cert myrsacert1 certificate.pem; ssl associate cert myrsacert2 certificate.pem...
Thanks for your help,
Best regards,
Claudio
pablo.nxh
Level 8
Level 8
Hello Claudio,
- When generating the CSR can i use *.mycompany.com for CN?
Yes that will take care of any subdomain you need... something that you need to consider is that this wilcard will cover site like cars.mycompany.com or shop.mycompany.com but if you have a site that looks like ftp.shop.mycompany.com then you'll need a wildcard that looks like *.*.mycompany.com.
The CSR is generated only once and from there you send it to your CA to have signed off.
Not sure I fully understood your second question, once you received the cert and key whether in PFX or PEM format from your CA, you'll upload these to your CSS using FTP and then associate the file(s) to a name that is only meaningful to the SSL proxy list within your CSS.
__ __
Pablo
pablo.nxh
Level 8
Level 8
Hello Claudio,
__ __
Pablo
