L2 and L3 Forwarding Method in the Same WAE
lomonaco
      Hi Everyone,
      Is possible to use simultaneously L2 and L3 Forwarding Method (WCCPv2) in the same WAE.
      I wanna to design a cluster with 2 WAE using the same service group in a DC and I wanna support both the L2 and L3
      Forwarding Method at the same time..
      If yes, is there any link when I can get a documentation showing some example configuration
     Thanks in Advanced,
     My Best Regards,
         Andre Lomonaco
Hi Andrej,
         If I understand this correctly, then your best option is to use G-GRE (Generic GRE) as egress method, and use GRE redirection and MASK assignment. See an Example below.
wccp router-list 1 172.16.10.1
wccp tcp-promiscuous service-pair 61 62 router-list-num 1 mask-assign
wccp version 2
egress-method generic-gre intercept-method wccp
For more details, please follow below CCO URL.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v441/configuration/guide/traffic.html#wp1041742
Ahsan
6 Replies 6
ahskhan
Hi Andre,
         In a single WCCP Farm, (same Service Group) you need to have same Redirect, Assign and return method, otherwise WCCP will run into issues. Can you explain more as what you are trying to achieve and may be I can help?
Ahsan
Hi Ahsan,
    Thanks for your prompt reply..
     I have an scenario where I have 2 DCs with Asymmetric Traffic, so I wanna to use the approach to do the transparent interception logic across the WAN Edge Layers in both DataCenters. I think I must use a single WCCP service group in this scenario with L3 Generic GRE.
    My doubt is if I can use those WAEs to do, both L2 and L3 WCCP Interception, cause I will have L3 traffic through the 6500 Wan Switches and L2 too
Hi Andrej,
wccp version 2
Ahsan
Hi Ahsan,
    Thanks a Lot for your help
    My Best Regards,
     Andre Lomonaco
Hi Andrej,
wccp version 2
Ahsan
ahskhan
Hi Andre,
Ahsan
