CSS Advanced Load-Balancing Cookies
sjumel
i'm using CSS 11501 to load balance some web servers with advance-balance methods cookies.
which is best the method of loadbalancing
with it sticky method ??
balance leastconn or balance roundrobin
Thank you in advance!
Gilles Dufour
there is no general better solution.
It depends on what you want to achieve, the type of servers [do they all have the same power ?], the type of traffic, ...
I would suggest to use the default which is roundrobin.
If you see problems like more traffic to one server, or a server being heavy loaded while others are not, you can then try leastconn or something else like weighted round robin.
Gilles.
