CSS problem
sushilk
Level 5
Level 5
Hi Gilles
I have a one armed network configuration of my CSS. I had four web servers which are being load balanced. These web servers in turn connect to two billing servers. The Clients are able to access the web server but when they try and access the billing information then the connection gets disconnected. Is there anything we can do.
The configuration is as follows.
GLOBAL
ip route 0.0.0.0 0.0.0.0 192.32.10.254 1
!************************* INTERFACE *************************
interface e1
bridge vlan 1
interface e2
bridge vlan 1
!************************** CIRCUIT **************************
circuit VLAN1
ip address 192.32.10.11 255.255.255.0
!************************** SERVICE **************************
service Datab1
protocol tcp
active
service Datab2
ip address 192.32.10.2
protocol tcp
active
service web1
ip address 192.32.10.20
protocol tcp
active
service web2
ip address 192.32.10.21
protocol tcp
active
!*************************** OWNER ***************************
owner XYZ
content RULE
vip address 192.32.10.10
add service web1
add service web2
protocol tcp
port 80
add service Datab1
add service Datab2
active
GROUP
group billing_service
add destination service web1
add destination service web2
add destination service Datab1
add destination service Datab2
active
Gilles Dufour
I would start by sniffing vlan 1 and see what is going on.
Gilles.
twinfield
Community Member
From your config it looks like two of the four web servers are also being used as data repositories server(s). Is there multiple IP address bond to those server(s)? You?ve created a basic content rule that only tells the CSS port 80. Also you may be sending all the traffic to one server, since you haven?t specified a balance type (balance srcip) in the content rule. Depending on your configuration you might look at creating another content rule and group for the data portion. Since your running one arm, I assume there is a lot of network variables involved, just a thought.
