CSS SSL renewal problem
Sagar Purohit
While renewing the ssl certification in CSS everything went fine while installation but after that when i checked with the following command
sh ssl associate rsakey | grep url(dont want to mention name)
i can see the previous as well as the new both key as associated and says yes
while the new should show yes and old should be no
same it is showing for cert
can anyone help me to sort out with this problem what it can be
Thanks in advance
dpastor
Level 2
Level 2
Sagar,
Have you performed the "no ssl associate rsakey" and the "no ssl associate cert"?
After that, perform the "clear ssl file " and "clear ssl file rsakey "
Dave
Hi Dave
I tried the above steps but its not working
Is there anything else I could do for this to work
Sagar
Sagar,
If you are using SSL proxy list, you have to remove the ssl-server associated with the cert in question and add it back with the new cert.
Dave
