WAVE 694 TCP connection limit
901563ravi
      Reading documentation on WAAS 694 , it says that it can do 2,500 connections and a lic upgrade is required for 6000 connections.
I cannot find the lic part number on cisco.com.Can anyone please help me with this understanding or does WAAS 694 do 6000 connection out of box.
Also With CMS do you require it do be on a dedicated appliance or can be deployed on the existing WAVE device.
Ramu
finn.poulsen
Level 3
Level 3
Hi Ramu,
The is no license involved in this upgrade, but you'll need to purchase additional memory :
MEM-694-24GBWAVE 694 24GB memory
and when installed to a "disk delete-data-partitions" and reload to resize the DRE cache area.
Be aware that this will clear any DRE- and CIFS cache as well as virtual blades configured.
Best regards
Finn Poulsen
