CSS to transparent Proxy load-balancing
Aabed Khalifa
Community Member
We have a single bluecoat proxy that is exposed to internet ,  which we need to add another one and load balance traffic to both of them . The problem is that this traffic cannot be routed to proxy explicitly ( i.e not like the Ineternet Explorer ) so this loadbalancing has to be done blindly to the users .
So is there a way or another that I can loadbalance internet traffic to these proxies with an inline CSS or maybe L2 loadbalancing to the proxies without involving a VIP ?
I was thinking about making the CSS VIP the default gateway of the clients so that traffic hits by it and make the 2 proxies the two real servers behind this VIP but I'm not sure if this will hit through the rule before routing traffic or not .
6 Replies 6
sivaksiv
Configuring a VIP with 2 proxies as real server is a good option and you just need to make sure the client is able to reach the VIP.
Siva
Thank you Sivak , I still don't get what you mean . Do you mean have the VIP the gateway of clients ?
Thats correct.
Siva
check this solution :
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a0080093ff3.shtml
it should do what you need.
If you have any question on this, get back to us.
Gilles.
Thank you Gilles , I was hoping that YOU see and reply to this post
This sounds logical to remove the VIP , but I am not going to connect the CSS physically inline , I will make it the gateway of the clients so that all traffic hits by it and then by the rule .
Do you have concerns ?
no concern.  Should work as well.
Gilles.
