CSS with Advance Balance cookies -timeout issue
alan.lund
We have a CSS configuration in which the CSS sets a cookie, but it never expires. Can we use the sticky-inact-timeout on the following setup?
I believe the answer is NO, as this is only related to IP stickiness
content offloaded_crw03
vip address 10.1.1.1
add service crmtst231_11000
add service crmtst232_11000
port 80
protocol tcp
url "/*"
add service SuccessNet_redirect
arrowpoint-cookie path "/"
arrowpoint-cookie name CRW03base
advanced-balance arrowpoint-cookie
no persistent
active
6 Replies 6
Use "arrowpoint-cookie browser-expire ". This command will delete the cookie on browser exit.
More details at
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20/command/reference/CmdOwCnt.html#wp1140231
Syed Iftekhar Ahmed
I would like to let the CSS expire the time, so can I just use the following command to allow the CSS to expire the cookie after no activity.
arrowpoint-cookie expiration dd:hh:mm:ss
"arrowpoint-cookie expiration dd:hh:mm:ss " command has nothing to do with inactivity. It sets an absolute time when cookie will expire.
Did you see follwoing under "Usage guidelines"
"When you configure the arrowpoint-cookie expiration command and the advanced-balance arrowpoint-cookie command, the CSS CPU may spike and the CSS may experience a degradation in its performance. Configure the arrowpoint-cookie expiration command only when necessary."
Syed Iftekhar Ahmed
Yes, saw those commands and did see the possible cause in spike CPU. We have tried most of the cookie expire commands and nothing appears to resolve the issue.
What we are looking for is if there is no activitely for a period of time with arrow-point cookie that the CSS drops the cookie and disconnects the user. Most of the users are not closing their browsers, and the usage of the arrowpoint-cookie browser-expire seemed to cause more issues withth application, than it helped.
Hello Alan,
Once the ARPT cookie has been delivered to the clients browser they must delete the cookie or they will continuously be bound to the same server as I'm sure you have found out. The CSS will not delete an ARPT cookie based on inactivity however, you can apply an expiration time to the cookie. As stated by Syed applying an expiration date to the cookie could cause the CPU usage on the CSS to spike, so it would be best to verify the cpu utiliziation before and after enabling.
Command:
sho system-resources
Will show the cpu utilization of the modules on the CSS.
If you wish to use the sticky-inact timeout on the content rule then you would need to change your advanced-balanced method to L3 persistance and discontinue the usage of the session cookie. The sticky-inact will actually remove an entry within the L3 sticky-table based on the inactivity time on the clients session.
Hope this info helps!
Thanks, with information is very helpful, as we started to make the changes mentioned.
Again thanks, Alan
