CSS11501 Sticky connection based on msisdn field
bmlakar
Hi there,
Mobile GSM clients connect through WAPGW over CSS to real servers. We want to stick their connections based on msisdn field. As it seems this field is not recognized by CSS since "lookup fail" counter increases ant there is no match. We have tried with header-field msisdn exist and also with partial match of phone number just for testing purposes (header-filed msisdn contain ...). The result was the same. I believe this can be a case of description of msisdn field in http header which is not standardized and depends on WAPGW. Our WAPGW is sending this field like "User-Identity-Forward-msisdn=". How can we convince CSS to recognize this field?
Thanks for help.
Branko Mlakar
Gilles Dufour
Branko,
the CSS looks for the following header => MSISDN: .....
Anything else will not match.
This is not configurable.
Gilles.
THX, Gilles.
regards,
Branko
Gilles,
Is this upper case or lower case or either, that CSS will match?
Alan
