Current Active Optimized TCP Preposition Flows: 24 - Limit ?
anthony.brewley
Hi all
I have 2 x wae-7341 devices in a farm at our data centre.  I have a preposition job running to serve some data to approx 100 edge SRE's.
This has been running for a few nights (due to schedule) and I have been checking b/w usage at our core WAN link.
This only ever reaches approx 1/3 of capacity and I started wondering why we were not driving more data.
Looking at the 2 x 7341's it appears that the TCP preposition flows never reach above 24 per 7341 at any one time.
Is 24 a maximum number of pp flows ? If not, any idea why this number may be so low as I have asked the PP job on the CM to PP to approx 100 sites concurrently ?
We are running 4.3.3 s/w.
7341 (a)
Current Active Optimized Flows:1097
   Current Active Optimized TCP Plus Flows:1060
   Current Active Optimized TCP Only Flows:13
   Current Active Optimized TCP Preposition Flows:24
7341 (b)
Current Active Optimized Flows:1012
   Current Active Optimized TCP Plus Flows:979
   Current Active Optimized TCP Only Flows:5
thanks
Anthony
2 Accepted Solutions
ktunugun
Hi Anthony,
Only 24 downstream Cisco WAAS devices at a time can actively receive prepositioned files from a single core Cisco WAE. Additional Cisco WAAS devices assigned to a prepositioning job must wait for the completion of one of those processes. This delay must be taken into account when sizing a Cisco WAAS deployment for CIFS prepositioning.
Given a maximum of 24 prepositioning task processes per core Cisco WAAS device, specifying more than 24 destination sites can significantly extend the time required to complete a prepositioning job. Verify that all files in the prepositioned directory are actually needed at all sites. If they are not, construct multiple prepositioning jobs segregating the sites to receive only those files required. If all files are needed at more than 24 sites, divide the prepositioning job into multiple prepositioning tasks that start at different times
Kiran.
5 Replies 5
ktunugun
Hi Anthony,
Kiran.
Kiran
Thanks sincerely for the reply.
I suspected this may be the case but have been unable to find this '24' limit, documented anywhere.
Could you point me in the direction of any documentation which 'officially' confirms this.
thank you
Anthony
Kiran
thanks once again, this is very very helpful.
regards
Anthony
Hi Anthony,
Please see the correct URL below:
https://communities.cisco.com/docs/DOC-12826
Kiran.
