Custom Header Field Question
alanwright1
Level 3
Level 3
Hi Folks,
If I configure CSS for a customer header field, will it allow me to configure advanced loadbalancing on this header field?
TIA
Alan
Gilles Dufour
the header field option is just there to allow you to match traffic to a specific content rule.
The loadbalancing functions are no different weither you use the header-field or not.
Gilles.
Thanks Gilles,
So I guess you are saying that I cannot do advanced-balance on this customer header, as there is no advanced-balance custom-hdr command
Alan
