debug commands for load-balancing on ACE
ROMAN TOMASEK
is possible to debug the load-balancing decision which is provided by ACE? For example: when the traffic comes to the VIP address I need to see which serverfarm is used for this traffic and which rserver was choosen for this traffic. Thank you.
Gilles Dufour
no, you there is no debug to see the decision.
You could capture the queues infos and see what it contains but it is quite complicated.
A simple way is to capture a sniffer trace of front-end and backend simultaneously and you will be able to see where the traffic was loadbalanced.
You can also use the capture feature of the ACE module to get this info.
Gilles.
thank you. Is a plan for these debug commands in the future sw releases?
