default gateway on a leaf
axfalk
Level 7
Level 7
Does the default gateway get created on a leaf as a result of configuring the Bridge Domain with the specific default gateway address or an end point getting directly connected to that leaf?
Thanks.
_Greg
axfalk
Level 7
Level 7
in other words, how do you tie a tenant to a switch?
Thanks.
_ Greg
harshal.shahane
Level 2
Level 2
Hello Greg,
The Bridge Domain that is created in the fabric does not have association to any leaf. Association to a particular port on a leaf switch is done by attaching the Physical Domain to an EPG (EPG is associated to the BD)
Harshal
